  • Replies 14.2k
best place to get rocker cover gasket.... main north nissan since they a club sponsor?
Ive bought a shitload of parts from main north nissan of late, and they are very well priced - some cheaper than what people in the eastern states are getting, then we get an additional 10% off!
Also bought parts from this place before, $93.50 for the kit (both sides and the half moons). >>Kudos Motorsports<<
What's everyone doing tonight?
I thought I might try having a go fitting up the Blitz LM FMIC I bought ages ago.
Unfortunately, I can't get it to fit without cutting the reo - which is something I really didn't wanna do (specifically bought the Blitz cos I was assured I wouldn't need to cut reo).
... pondering taking a pass on it and selling it on now ... *sigh*
On an even crappier note, when I went to fit the FMIC found someone has what looks like punched my front drivers-side guard; Guessing it was earlier tonight when I was parked at shops, came back and a bunch of young punk-types hanging around their cars just across from mine - all laughing between each other n gave me shit when I drove off. Wish I'd realised at the time.
So - anyone know anyone who does cheap paintless dent repair?
Crappy night has been crappy.
I did the same thing when I tried fitting my Blitz LM FMIC (been sitting in garage for 6 months!). 50mm needs to be taken out of reo and I was thinking this is bullshit and will void insurance.
I phoned Shannons and talked to 2 different people on 2 different days and they both told me that as far as their concerned it won't void an insurance claim so long as I tell them it's on there. I explained to them that cutting the reo will have an effect in a front end accident but they told me that because it's an import then likely it's going to make repairing the car expensive or a write off anyhow. When I eventually get around to fitting mine, I'll get one of those radiator cooling panels which should disguise the cut reo at least when looking from the top.
Hey mate, give this guy a ring, I've used him a few times before. He is fast and efficient and reasonably priced too
Action Paintless Dent Repairs
David Allanson
0407 641 339
and PS: I've had a car pass regency with no reo bar and 43 zip ties holding the whole front end of the car together. Bumper, grille, brake lines, headlights, etc etc etc
soooooooo
Ive been in hospital, cardiac unit
had a small heart attack friday arvo
out of hospital now but out to cardiology specialist unit for more examinations soon
heart was over 200bpm for half hour & trying to come out of ribs Aliens styles, left arm went dead, then 130-190bpm for 24hrs
feel pretty ratshit now
anyways, yeah
fullon
Im in need of an car electrician.
Adjusting my air con makes like a buzzing noise, radio / dvd player drops signal and "seeks" a lot. I didn't wire it, but i did have a look and its a horrible job. Plus there are other wires and looms everywhere with electrical tape that I have no idea where they are going or what they are for (after market im sure).
Anyone help me out?
soooooooo
anyways, yeah
fullon
Damn, thats no good at all Brendan, hope you get well soon mate :D
Anyone help me out?
The air con noise might just be the actuators are partially seized up, just operate everything each time you get in the car and see if it frees up. Thats what I got told to do.
Is it a Jap radio or an Aus one?
f**ked up hey
felt 20yrs slip off my life span
cheers
that sucks to hear Brendan. Wish I did have time to drop by yesterday. I'm at the hospital atm. Slight training accident. Waiting for xrays. :D
your only a young man yourself to early for heart attacks unless its because you just cracked the lap time @ mallalla or something
how frail the human condition really is
yeh I know
4 weeks ago I wouldnt have worried about it - state of mind at the time, but now more positive after seeing headshrink / new antideps so figured I better get to the hospital
always had a heart murmur (faulty valve) and an irregular heartbeat but never been concerned about it, more on the mind re: knees
was what youd call a 'small' cardiac arrest, perhaps stress as Ive been stressed out with lose of house, marriage breakup etc
seems my heart is irregular like its got a gummed up spark plug, not sparking correctly
they can go in and cauterize areas where the electrical currents are 'shorting' and fix up that way, so tests to see whats up this week
