Hey anyone know much about bikes here (possibly ruby, although im talking lil stuff around bikes here)
im planning on getting my mate a pit bike trial bike thingo to use on his farm. doesn’t need to be fast just aslong as it go's and we only light weights so doesn’t need any power.
was looking at possibly one of these but not really sure just yet.
http://cgi.ebay.com.au/125CC-TDR-ALLOY-PIT...=item1e5d39f68a
any bought any of them?
Get one with a Lifan 140cc motor if you can. See my mate Brian at East 50s if you can. He sells better bikes than ebay. Or if ur going ebay, try looking for DHZ bikes.
  • Replies 14.2k
Welcome back blacky. When can i grab my club polo :)
I have it with me and your welcome to come and grab it anytime you want vanilla boy :)
and my jerry can krishdawg
Same applies for you Jose :D
What is the reason for only looking at Duel Solenoid EBC's?
Turbosmart E-Boost 2 would be my choice (infact i bought one a few months to replace my DSBC) but they aren't duel solenoid and they don't need to be.
Looked into E boost 2, but at near on $1,000 I'd rather a cheaper option that does exactly the same job.
I don't know much about EBC's, but from my understanding the duel solenoid is better for controlling and holding the boost. Last thing I want is it spiking or dropping off later in the rev range.
Dales right, no need for dual solenoid. Picked up one of the new Eboost Street for the R last year, think it was around $450 not long after release.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
