Just went and had a look at them again, they are from a 32. Rotors are 330 and measured 31mm thick slotted, come with brackets and near new pads with about 15mm of pad on them and braided lines for $2500.
Oh, and they come with a seal kit.
Edited by DSTROY
  • Replies 14.2k
How much bigger/better are F50s compared to 33R Brembos?
piston size there isnt much in it, f50's are 44/40, where gtr's are 44/38 i believe... f40's are the same iirc, 44/38.
funnily enough, the pistons in evo brembos are bigger again, 46/40, but theyre harder to adapt.
the biggest benefit with the f40/50 calipers is the size rotor they can take. bigger rotor = better heat sink.
Edited by scandyflick
Brakes do my head in. I know nothing.
In even more confusing news! I want to paint my engine covers but have no idea what colour to do them in!
brakes themselves are simple once you wrap your head around the physics involved.
id go bright f**king pink. but thats me.
34R brembo's arnt that good on the track I must admit.
ha. they'd be more than adequate on my car.
anyone know how much itll cost to have some wheel centres powder coated? im gonna do something with my wheels to pass the time.
and dale, i see you lurking, how many cartons to get a diff reshimmed? mines feeling a little loose, could use a tighten up.
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
