  • Replies 14.2k
or just run some tubing from the engine bay and place the other end right infront of your balls. youll soon know when to back off the accelerator
haha ouchies... painful to imagine :) < never seen that icon lol
Rich people that can afford to mod an already really exensive car shit me >_> lol
hey man you gonna do another cruise again? i liked the other one july.. i think it was b4 that person damaged your car
some one post inbetween me already! any1 know if when you get a custom number plate is that the only 1 of its kind in all of aus or can you say for example have a "RIPP3R" with dif state letters?
EDIT 4 CRAIG :Craig: they are posts 7 mins apart im going in and out of every post and shit... i havnt spent much time on these forums and i keep stumbling over different things... besides im allowed to dribble in this thread and i saved 1 post and did it in here for you.. happy?
il be on my wat to vilis soon anyways so there will be peace and quiet just for you :)
This may answer your question.
Man....Lax.
you need to go have a wank, get some tension out.
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>&">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
lulz
ha ha no worries dude, my run of bad luck didnt end there!!
went to ''smooth'' garage today to pick up the new 20.
well, Cam cover, timing adjuster thingy, coilpacks, crossover pipe, AFM all missing!
rang jeff, not happy. im not gonna buy it till all the rest of the parts are there. simple.
rang jap motorsport, they have one, engine and loom, COMPLETE for 1g.
had compression test before removed, 145 across all 6.
Hey craig
Ring TT and ask them of they still have this engine sitting down there. AFAIK it has just been sitting in the corner since it was taken out. so it would have done <1000km's since having a standard rebuild.
http://www.skylinesaustralia.com/forums/Tu...turbo+tune+RB20
Edited by D_Stirls
Hey craig
pretty sure its in an S14 now
That's what they put it in for the experiment but that's running a RB25/30 now (Their Orange Drift Car). Last time i was down there getting Jeff to tune my car it was just sitting on a stand in the corner. Michael said that if someone wanted it they could have it (For the right price)
Edited by D_Stirls
there 20 will prob be more than im willing to spend tho? did he say how much?
that 25 is missing too much shit, key word here is budget.
You'll ahve to ring micheal and ask but i don't think that they'd be after that much for it, it was built from parts that they had on hand.
Just had a look at that 25 listing and it isn;t missing that much. could get the rest of the parts for around $400.
Oh and they might think that it's an R33 engine but look at the CAS it's actually a NEO, so you could have a win there.
Damn that sucks balls man, what a fk around.
We nearly had my engine out by about 3ish this arvo. My mate went back to do a bit more when I went to work around 4 so hopefully the old 20 is out and we're ready to prepare the new one to go in tomoz.
Guest
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
