On the cruise last night, Allen (aka 2LV8ETR) removed the restrictor from Scott's (aka reaper83) car for teh extra boost.
I believe scott's is a rb26? is that dett? stock turbo? Afterwards he was saying how his stock pressure gauge was hitting max (+7mmHg). I believe +7 is equal to around 14.5 psi, right?
I'm interested in getting more boost out of my car also...but on the rb25det, stock turbo blows up if you push it much more than 12psi, right? what would removing the restrictor in my car do? is it safe?
also...i've ordered a turbotech manual boost controller which i'll be installing once it arrives. also want to know if i'll gain by having the boost controller and the restrictor out.
ty, ty.
https://www.sau.com.au/forums/topic/291921-removing-boost-restrictor/
I don't think you have a restrictor in the 25
And the boost could be a lot more than that. Don't use factory boost guage when you up the boost. Buy an aftermarket one or use the reading on your electronic boost controllers.
Edited by SKYRYAN
Only the RB26DETT has the restrictor in it near the PCM, RB25DET's don't.
As far as the RB25DET's are concerned, I wouldn't push one past 12psi safely.
In saying that, V8EATER was caning his RB20DET around pushing 18psi before we dropped the RB26DETT in, but it would only have been a matter of time before the turbo failed.
I personally think that it would of failed ages ago if i didnt have a electronic boost controller hooked up to it. Electronic boost controllers make a huge difference to the way the turbo spools, spikes etc
We will see how long it lasts when i finish my 4wd beach buggy with the old 20.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
