Hey all,
been a bit quiet in the cruise stakes for a while hasn't it?
Anyway, was thinking, why don't have an SAU Xmas party??? Aussie style, maybe go to Park/Beach (etc) and have a massive BBQ?
Any interest? 20th of December or something?
-Max
https://www.sau.com.au/forums/topic/29194-sau-xmas-party/
  • Replies 109
We should try to arrange some designated driver/car pool type thingo. I can give lifts - and can lend the Niva to another over-25 driver sans car - to do same.
You want to open this up to general population? There's alot of keen people who don't have access to this forum.
https://www.sau.com.au/forums/topic/29194-sau-xmas-party/#findComment-601081
Guest RedLineGTR
i assume thier is a bbq there..??
if so i would be keen to purchase the food for the bbq...alot of food :cheers: and drinks to..in return i would just collect donations either for upcomming club or to donate to christian for the server etc. But i dont have my car atm so i would need a definite lift if people are keen to have a bbq. Cheers Rob
https://www.sau.com.au/forums/topic/29194-sau-xmas-party/#findComment-601088
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
