I can get the auto lock thing installed for ya if ya want moanie
hmm.. crap, we're whoring in the spotted thread....
Umm...umm... oh yeah, spotted POS-... grey 33 series 2 at UAS last week when I picked up my flywheel. There was a brand new shiney intercooler in the front. :thumbsup:
i spotted our R32 coming out of a spraybooth yesterday wearing "Kitchen" silver....
Kitchen silver :bahaha::thumbsup::bahaha:
I so have to see this kitchen guys
mm GTR silver kitchen :drooling:
