This car has had a full rebuild with forged pistons shot peened rods o ringed block ported head (cost me $6500) brass button clutch ms fuzzy logic boost controller vee port turbo smart blow off valve it has a cusco styled mechanical lsd (might be a cusco i dont know) Just start making offers ill concider most. It also has large front mount inter cooler gtr styled front bar and a turbo timer every thing else is standard my number is 0422271237 my email is [email protected] all receipts available
this cars air con is band new apart from the condenser this car is as is and highest bid over 15 000 will get this car (legitamit bid must be sold befor Thursday
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
