R32 Gtst Dash Cluster Plastic Surround + Center Vents
Hello,
I am looking for a replacement R32 dash surround and the center air vents.
Regards
Johnny
Thanks for the Pm's guys .. I would reply but I apparently have to have 10 posts before I can :(
Just clarifying - I need the plastic that is around the gauges (speedo / tacho etc) which also includes the lights / wiper switches.
Thanks
Johnny
depends if you want a gtr or gtst dash surround
forgive my ignorance but what are the differences between the two, and will a gtr dash surround fit into my gtst ?
Thanks
Would you be interested in a GTR dash cluster aswell to go with the surround? $100 perfect working order only 71,000 genuine kms...
pretty sure, we have already Pm'd you, but we have a dash cluster surround and center vent in pristine condition, the surround is from a r32 gts4 and the center vent is from a 32 gtr... PM us if your keen
I'll take it, I will give you a call tomorrow or Friday to organize. :)
Regards
Johnny
Hey Sebastion , I am 2 posts away from being able to reply to pm's (SAU rules : 10 posts to reply)
Thanks anyway but as above I have found a dash + surround for $100
Regards
Johnny
  • 4 weeks later...
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
