It's through CAMS... basically protects the club & organisers of the cruise from any public liabilty. Or any other event for that matter.
Should someone from the general public organise a cruise/event (like DECA etc), if something went bad, liability would rest with them as organiser... and they wouldn't have insurance :banana:
So its as much to protect the club, as the club rep organising the event from claims that might arise as part of public liability.
10 years ago, probably irrelevant, but given todays day and age with regards to lawyers suing people for getting out of bed - good thing to have insurance :)
It is not like car insurance or whatever for you personally. That is for you to work out.
https://www.sau.com.au/forums/topic/292171-r34-s-meet-up/#findComment-4901998
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
