  • Replies 42
yeah revhead, regional flights are notoriously scary, especially from gladstone, its $161 cheaper if he flew to rockhampton, and thats 107km further north, sometimes i just dont get it. As for the tuning side of things, im hoping to get a tune done thats adequate and safe to drive it to a shop then mark@godzilla can do the hard yards and get me the numbers!
The reply's and suggestions have been great guys, there greatly appreciated!!
Cheers, Allan
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4889762
Just got mine back now drove it home, seems to run a bit smoother then before. but i was having afm issue and also 02 sensor is playing up so gotta replace that other then these issues its seems to be running ok in the engine dept.
cheers
Daz
Vi-PEC or still stock ecu ?
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4890715
Nah Vipec installed today.
Sorry i mean i was having afm issues before i got the vipec installed and removed them. but the 02 sensor still seems to be another issue i have to address.
P.S. i saw your plates sitting on the snap on tool box today paul! :happy:
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4890719
they drive nice dont they Darren.
yes my car lives in qld...pity i don't
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4890896
seemed to drive better on the way home, but that wouldnt be hard to do after running dodgey air flow meters. lol
but i didnt get it tuned for max power or anything pretty much stocko still at 0.8bar , want to conserve turbos etc till i decide to upgrade. but still have to look into the o2 sensor replacement.
But yeah mark was great to deal with very helpful.
Good bloke.
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4891425
Good bloke.
yeah he said he enjoyed working for you...he thought you were a little cautious/sensible...not really the normal customer. Most say turn the boost up...i want a big number etc...you however were patient until you have turbo's upgraded and all the proper support systems in place before turning the boost up. Its a nice safe tune that will look after your hardware till you are ready to take the next step.
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4892422
Yeah just dont see the use of blowing up engine if i dont have to.
and having a garden ornament.
il wait till i can do it properly.
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4892940
Well, it arrived yesterday! Im about to tackle the ecu install into the factory ecu case over a few rums. Looks the goods, has a good spec sheet and a few people seem to say dam good things about them. Any quick tips before i get insanely frustrated and drink myself into oblivion?
Cheers, Allan
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4896905
Cheers, Allan
a really hot soldering iron on the factory screws to remove them...dont forget to drill the hole for the vacuum line.
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4896911
Vi-Pec is in! not so hard. i just double triple double checked everything tho! Now, im at a dilemma, do i sell off stock parts and fund a new set of -5's or do i bite the bullet, go over budget and just buy em or get a set of high flows and hope i can get my goal?? also, can anyone recomend a good...nevermind, ill make a new post. :(
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4899678
i pulled a power fc out of my rig to make way for the new vi-pec..... much better ecu and i got more power an torque with better driving on the street.
highly recomend.
mercury motorsport installed and tuned my in case ur curious.
so many on here would fail to accept this is actually possible...yes it was hard for them to fathom that something designed, engineered and built this century could actually be better than a similar product from last century.
Engine control is phenomenal...the Vi-PEC made my power fc look like a bucket...but i must admit i used to be an 'FC Fanboi' too.
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4910946
Heh I'm at the point of doing a fuel system for my T88 powered FD and the power FC is just not up for it.... high impedance injectors only unless you want to run dodgy resistor packs, I'm trying to run the new Siemens 2430cc as secondarys and if I stick with the power FC I'll end up having to use something like an FJO / AEM injector driver
Seriously considering an M800 as that's what my builder uses in his car, but I may explore the VIPEC V88.
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4911321
hehe
marks just retuned my vipec with my new turbo (hks 2540) and new rb25det (cracked ring in old one) as well as added more goodies in (nismo 740cc's, tomei FPR)
mark is a top guy who gives you the right advice!
hey dirtgarage... is that your greeen/purple (duno what color it is) gtr that is always there.. number plates RH9? if so.. i f**king absolutely adore that car.. that thing is nuts
https://www.sau.com.au/forums/topic/292301-vi-pec/page/2/#findComment-4919824
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
