  • 3 weeks later...
  • Replies 47
  • 1 month later...
  • 2 months later...
  • 4 months later...
  • 4 months later...
Well i still Have this interior in storage. and want it gone. havent been on sau for a while now, so thought id drag this one up. please contact me if you are interested in this interior.
Will take $500 for the lot if any one is keen for an upgrade.
thanks for the offer. but i wont go that low. i want it gone but still want to get my asking price above, as it owes me more then this anyhow and know its worth it. i have had it sitting around for over 12 months now, so not really in a hurry.
any one who wants to take it off my hands for the lot $300 pick up. PM Me
Cheers.
Daz
  • 3 weeks later...
  • 2 months later...
i would take the rear seat if you were coming down to the gold coast any time?. im so after that seat ;) .i would take the door cards.. but it looks like the door in the left pic has a bubble or something near the front of the door card :(.. im really after perfect cards.. hehe... thanx
Hey yeah, i could work something out maybe meet half way or something PM me and we can go from there. The door cards are in good condition, i could bring them for you to look at also if you like. Cheers
Daz
hey.. sounds ok hey.. i want the red interior?.... hey,,, is that a lump or a mark on the left door?.. or is that a flash or something... im so picky at things that cant be retored.. hehe. sorry.. thanx..
i never noticed it to tell you the truth, these are packed into storage and wrapped up atm. it could be a slight blemish, but it certianly wasnt major. anyhow just PM me, and we can go from there
Thanks
Daz.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
