Hey guys, ive bought a damaged pulsar as a repair project and havnt got round to fixing anything due to the reason that im now moving houses and can't keep it at the rent.. (it was hit in rear right,rim and axle wich has been removed) the rest is in good cond having a few minor dings and problems and the car is blue. some parts havn't been striped, if interested in any please call me so i can arange to get them of if needed.thanks.
selling:
front right door and trim-electric/s (been slightly kinked in middle and mirror is cracked) $220
front left door with trim-electrics/s (slightly kinked in middle and slight damage where fender is) $220
rear left door with trim-electric/s $300
boot lid with wing and tail light pieces attactched(minor ding on right)$350
rear bumper-minor damage $150
front bumper $200
front fenders with indicators $100 ea
front indicators $50 ea
headlights $150 ea
front grill $120
bonnet $320-very minor sun damage spot
black bumper support piece $100
All interior is pretty much available aswell can strip if needed separately(carpets,seats,dash,ctr console,steering wheel with airbag etc.)
2L sr20 engine- $1000 ono
manual 5sp gearbox (incl clutch, may have problems or possibly just the bearing) $1000 ono
For the rest of engine bay parts please ask...
If you are interested in anything please contact me dirctly on my mobile on 0431 266 194. may be able to get phone pics and send them.
https://www.sau.com.au/forums/topic/292407-wrecking-sss-n15-pulsar-hatch/
  • 1 month later...
selling:
front bumper $200
headlights $150 ea
front grill $120
Hey mate, are these parts still available? I'm after the driver's side front fender (and maybe bonnet) - is it metallic blue? if still available I'd definitely buy it & add postage to send to vic? Thanks!
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
