I just picked this up as advertised an an "r33 recirc valve" however Im thinking that this isnt what it is. I sort of suspected this when I bought it but it was just a fraction of the $50 that most people charge for one on this site. Can anyone tell me what it is? or if it is possible that I could use this on my 33 gtst?
Edited by Crackfox
https://www.sau.com.au/forums/topic/292461-what-is-this-part/
I am pretty sure that it is a GTR type twin recirc valve and I am currently fitting one of the recirc valves to my skyline, I'm currently installing it and will see how it goes, looking like the only modification needed will be from the different pipe sizes which is an easy fix. Will see how it runs soon
OK so its a GTR bov? not bad for $10 then I guess:p The guy selling it didnt know much about it, he drove an audi and when I asked which model skyline he used to own he said he had never even owned a nissan so I dunno how he obtained it.
I have taken one of the recirc valves off and installed it on my skyline. Is the only difference between the gtst and gtr recirc valves the pipe sizes on the larger end? can anyone confirm this or are is there other changes as well?
Seems to run fine with the new recirc valve, now it makes a funny "pchieww" type noise instead of pshhhhttt at gear changes, the cars responsiveness also seems ever so slightly decreased though it is a very subtle difference which is expected I guess. The cars small backfiring issue and occasionally lumpy idle also appear to be solved.
just get a mirage 1.5 radiator hose and cut it and it will fit to gtr bov and gtst stock plumb back piping :cool:
i posted the part number sum where but cant seem to remember what part number it was
I just connected it by putting a piece of the smaller gtst bov type piping inside the larger gtr rubber piping, and then put a radiator clip thingie on it and joined it as normal. I don't think its leaking but I may test it further just to be sure.
*cough* dodgey *cough*
Why is it dodgey? Its a more secure fit than the stock plumback connection, if any connection does fail on my installation work it wont be this part. Anyway I would rate my work as alot better than the very messy previous atmospheric blow off valve installation.
Well the GTST ones aren't too flash for high boost and they do have a little hole in them that leaks off air a bit. People weld this up and then supposibly its fine for high boost. No idea why it is there from factory, maybe some one else can explain that. Perhaps a safety for a boost spike so it bleeds it off? I believe the GTR ones don't have this hole hence why they hold higher boost fine.
Edited by PM-R33
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
