Ouch man that looks painful! I would be checking your hub for cracks, and quite often a lower arm that bent will have bent the upper control arm too.
If you look around all these parts are available pretty cheap so not too bad, also if you've been considering adjustable camber arms, it could be a good time to do it :)
what the hell did you hit???
Lol a curb....should of just hit the damn cat
swaybar looks bent.. possibly castor arm as well
I was worried about those as well but I checked out the driver side rods and they seem to be the same shape...hopefully get a new LCA soon and it'll be sweet...need to get it fixed before Midnight CRUISE!!!!
hi james, vu from dt panels here
we repaired an r33 last week with similar damage to yours last week
we replaced the lower control arm and the castor rod didnt look bent but when we put everything back together the wheel was still castored back
so we replaced it with another standard item and it was fine again
probably best to replace it to avoid taking everything off again (they're only like $50-70 i think)
i doubt the swaybar is bent, the linkages allow them to flex a fair bit
remember to get a wheel alignment after everything
My theory is do LCA and radius rod, then take it for alignment and if he can get a good alignment and it drives fine, and the wheel aligner gives it a check over, he should be ok!
Swaybar links didnt look like they were under too much pressure.
Thanks for all the input guys!! John's old caster rod and Control arm is now on my baby and seems to be running great again, next a trip to the shop for some new treads, balance, alignment and a brake flush and hopefully will be able to make it for the midnight cruise! Just like to thank Jack (iirc) for taking my baby home, champ of a guy and makes it that much easier knowing your baby is on the back of a truck whos driver knows what it means to own a skyline.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
