Im getting a bit bored of my chrome rims at the moment..
So i wanna go to a different style
i was after black rims
i saw a pick of an R33 with stokies that were painted black
it actually loked half decent
heres the pic
does anyone have any other pics of stokies painted on??
cuz it doesnt show the side view
or does anyone have any black rims lying around and wouldnt mind selling em??
let me know
cheers
https://www.sau.com.au/forums/topic/292933-r33-black-rims/
  • Replies 95
i painted a set of r34 rims black with spraypaint. looks pretty damn gud and it looks heaps different and its easy as. make sure u use good paint tho or else it isnt very gud over time haha. if u want i can get u a set of cheap r34 rims (gtt wheels) painted black or cheaper if the silver colour they are atm if u wana get it painted professionally.
https://www.sau.com.au/forums/topic/292933-r33-black-rims/#findComment-4892802
def go with the black :P ive got a set of what i think are 32 stockis that are painted in matt black spray can dodge you can buy for $250 with tyres ( pretty bald) or.. like ive done to mine i can paint them in gloss black 2 pak paint for an extra $100 and they look killer and will last too
pm me if ya keen mate
https://www.sau.com.au/forums/topic/292933-r33-black-rims/#findComment-4899183
this whole paragraph makes me want to hurt people.
https://www.sau.com.au/forums/topic/292933-r33-black-rims/#findComment-4899759
grammar or the sacrelige of painting the 34 rims in black spraypaint ? what a noob
lrn 2 sp33k 3ngl1sh y0
that said, i have nothing against 34 rims repainted, but at least powdercoat em
-D
https://www.sau.com.au/forums/topic/292933-r33-black-rims/#findComment-4899859
-D
the grammar. i care not for the colour of his wheels. as long as he does it properly. powder coating is cheap.
lol why? its not written that bad
... you serious?
https://www.sau.com.au/forums/topic/292933-r33-black-rims/#findComment-4901782
mitch, if you have an issue with me, try taking it up with me in person.
i have an issue with a post, not the person, beyond that, i dont care.
as for the wheels, he can paint them from a rattle can if he wants, but it isnt that expensive to get powder coating done and the result is 9 times out of 10 much better.
am i still being an opinionated troll? if so, i dont really give a f**k.
this could get good.
it wont.
Edited by scandyflick
https://www.sau.com.au/forums/topic/292933-r33-black-rims/#findComment-4901807
mitch, if you have an issue with me, taking it up with me in person.
it wont.
why u have an issue with the post though? there was nothing wrong with it
https://www.sau.com.au/forums/topic/292933-r33-black-rims/#findComment-4901816
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
