  • Replies 95
I'll sell u my 34 rims for $450 with tyres :thumbsup:
3 outa 4 centre caps tho and tyres are very legal and been through regency fine.
You talking about these rims that i borrowed? They look ok without the centre caps.
Huge thanx for the rims Luke, I can now stop boring my girlfriend with all the dif sizes and prices I keep seeing online and wishing I had :)
In true Awsam fashion though, and further proof even the simplest of things with cars for me are made difficult..
My jack handle snapped while putting the rims on, so my skyline is now stuck suspended until a mate cbf'd comming over with theirs lol
use your spare jack that should be in your boot.
ive done the same thing not to long ago with my sil.
Spare jack.. tick
jack handle... um.. where? lol
Doesn't matter now anyway, got a 4WD hydrolic lifter to put them on. Doesn't matter which R34 rim i put on the front, they scrape my calapers. Makes a disgusting clunking noise and messes with my steering real bad. The calaper has left a perfectly straight groove in the rim *sigh..
I'm about done with this skyline, all the simple things i've had done to it have turned into absolute nightmares, this car has me completely exhausted and I think the next thing that goes wrong I'm just gonna get rid of it and go back to driving my Calibra.
They hit the caliper? they cleared my brembo's and chad's stag. Thats odd.
Yeh was one rough ride man, I posted a thread about my problem. Maybe I have different calipers than I'm supposed to???
Maybe there's something wrong with my suspension, the front drivers side is a little spongey, and the tyer on the R34 rim seems to be touching the arm bit above the wheel very slightly every now and then.
thread has pics of the calipers, will post a pic of the groove left in the rim aswell
http://www.skylinesaustralia.com/forums/R3...-C-t296066.html
Edited by awsam
Hard to tell from the pic. I'll see if I've got a small spacer for you to fix it rubbing.
I've got a set of 5mm slip on spacers that luke removed off my car a few months ago that u can have for $20 if u like?
-D
-D
How's the vibration with a spacer on the front? I was going to take an angle grinder to the caliper and shave a couple of mil off LOL! f**kin take that!
This thread has the pic of the actual front caliper
My calibra has similar looking Calipers to the rear ones pictures in that thread, but on all 4. I thought maybe my 33 was supposed to have the same style rear ones all the way around also..
Edited by awsam
I didnt know the spacers were on all 4 wheels when I bought it, and tbh I didnt notice a difference when they were off, so I can say confidently that if you bolt your wheels up tight, it wont be an issue :happy:
-D
-D
Hrmn I think I'm prob just going to have to do that. Will i need to put all 4 on? Rears sit perfect as is. Are spacers illegal in SA?
yeah, both slip on and hub centric ones are illegal but paint them black and itll be harder to see.
also, depending how big of slip on spacer your get i would look into getting longer wheel studs but thats just me.
and if you use hub centric ones, get lock tight glue stuff that can be found at any car place like autobarn along with slip on spacers
hub spacers can be bought at wheelworx if your wanting them.
luke, remeber taking my 34 rims off my 33. they have some decent sized hub centric spacers on there to clear the brakes.
34 rims will also need spacers on a 32
are slip on spacers illegal? my car passed regency with em both times. never even got mentioned whilst in there.
To glue the spacer to the rim?
you use the lock tight on the bolts in the hubcentric spacers to make sure they dont come undone. they come with a different set of bolts. dont use hubcentric spacers with the 34 rims its not neccessary with the 34 rims as 5mm spacers will do the trick
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
