Hello,
I am looking at dropping a S2 RB25DET into my Datsun 280Z. I am wondering about the entire buildup process and have been collecting a lot of information. One thing I cannot seem to find is the actual, physical design difference between RB25 valvetrain and RB26 valvetrain. I understand if they have different springs and whatnot, but from everything I have seen, they are both shim over bucket and therefore equal in design? I know RB26 cams do not cross with 20/25. What am I missing? Are the dimensions merely different? Anyone have a photo of the valvetrain of 25 vs. 26? I like the idea of the RB's rev-ability and want to know how the 25 is rated compared to the 26.
Thanks,
Mark from Ohio
https://www.sau.com.au/forums/topic/293159-rb25-vs-rb26-design/
26 has solid lifters and RB25 has hydraulic, thats the main difference. When you switch a 25 over to solid lifters there is next to no difference between the two, pm fineline on these boards if you want to know all the details, he got that all done and now runs 26 poncams in his 25 head. And in regard to revability the solid head will rev more as it wont have hydrailic lifters 'pumping up'
OK, now I am well and truly confused. Aren't the cam lobes riding right on top of the bucket/retainer/valve? Kinda like Subaru STi's? Where are the lifters at?
if you can get the r33 workshop manual it has a really good expolded view of both the heads, it is readily available for down load, its kind of a bit hard to explain and im at work so i cant download the pictures myself!
In the RB26 head seen from the cylinder up; first the valve, then the vavle spring around it, sitting on top of the valve is a shim for the correct clearance, on top of that the lifter to take the hit from the cam knuckle :devil: Very straight forward, standard design.
In the RB25 you've got the hydralic lifters with all-in one-design instead :P
BTW the rb25 have got smaller diameter valves, guess you know this already!
In the RB26 head seen from the cylinder up; first the valve, then the vavle spring around it, sitting on top of the valve is a shim for the correct clearance, on top of that the lifter to take the hit from the cam knuckle :happy: Very straight forward, standard design.
In the RB25 you've got the hydralic lifters with all-in one-design instead :)
Oh, so the 25 does not have a bucket, but rather a lifter that is axially inline with the valve. I take it there's no way to change to the bucket design short of buying a 26 head?
I found the manual. Thank you. I think I see how they are different. I've never seen a hydro lifter of such design. I guess you get the benefit of hydro lash adjustment without the possibility of spitting a rocker or adding undue weight to the valvetrain.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
