Hi Guys,
Up for sale is a long list of parts out of my recently rebuilt rb26 im stripping. The motor was an r33 gtr motor and all work was completed less than 3000km's ago (have receipts for work).
1. R33 RB26 Crank - $600 ONO
Crank was balanced and inspected with no issues at time of build 3000kms ago.
2. Complete R33 RB26 Head - $1000 ONO
This head was flowed etc (have receipts) 3000kms ago however now has a burnt valve on cylinder 1. Rest are fine and comes complete with standard cam gears. Also includes aftermarket cams however im not sure on the details of these (came with motor from build 20000km ago).
3. N1 Oil Pump - $300 ONO
Was running fine in the car. Was not replaced at time of this build so is 20000kms old.
4. Sard 700cc Injectors - $650 ONO
Roughly 20000kms old working with no issues in the car. Can include the required plugs.
5. ARP Head Studs and Main Studs - $500 ONO for both
Bought new for the build and are only 3000kms old.
6. Complete set of polished RB26 Covers - $600 ONO
Includes cam covers, coil pack cover and timing cover.
7. Eagle Forged Rods - $600 ONO
All 6 in great condition no issues at all
All prices are negotiable. I've got a new motor to pay for so need it all gone asap. If you have any questions either pm me or for a quicker response sms/ring 0403858714.
In the process of taking pictures so will upload when available.
Will post at buyers cost but prefer pickup from Rouse Hill, NSW.
Thanks,
Brett
https://www.sau.com.au/forums/topic/293197-r33-rb26-aftermarket-engine-parts/
  • 2 months later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
