meh, he didn't seem very keen to help me out to be honest, i think he just wanted me out of there... overall i was happy with the tune, but around town its a bit of a pain in the ass. i changed to hotter plugs and that helped quite a bit. steve tuned it, great powercurve etc, but i get the feeling it wasnt a "full tune", just a quick power tune or whatever. good on WOT, but needs more effort in the tune in the lower RPMs. i know john would be happy to have a look, but he'd be happy to charge me $$ to do it, and living in mandurah makes things hard.
my plan was to fit a larger turbot next year - i have all the ancillaries (inc forged motor) - and tune for about 350rwhp (sr20det)
can i get this done at sikpacks dyno with decent results? :down:
Hyperdrive or All Star garage , both in same street in malaga , Worth the drive for sure :down: 400k round trip for us too
Edited by Dsturbd
Is there gonna be a dyno day for skyline owners??
Ie a group session....
If so what would the costs be??
I am looking at getting mine on the dyno once my new rad comes, do you guys use det cans etc ie to watch afr for leaning or det??
The reason i ask that is because when i took "t" belt cover off to check the condition of belt i didnt mark up were the timeing should be, so i have put it back on in the middle after reading/being to put it there for safety...
Edited by GODZ1LLA
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
