Just got the whole conversion bits and pieces needed to do the 5 stud conversion ...
Front hubs , rear hubs , slotted discs , calipers etc...
4 piston front GTR
2 piston rear GTS-T
etc...
I am after a set of wheels since my car is 4 stud currently and I do not have any 5 stud wheels to do the conversion yet ...
Will also need 20 x M12 x 1.25 wheel nuts to go with
Anyone selling any at the moment ? so that I can do my conversion
https://www.sau.com.au/forums/topic/293445-wtb-r32-gtr-or-gts-t-wheels/
I have some 17" x 7 works wheels...
4 piston front GTR
2 piston rear GTS-T
etc...
Cheers for the pics , Dunno bout the works wheels don't think they would suit my car too well ...
Looking at getting some Weds Kranze LXZ wheels in future for it but need some wheels (stockies to get me by)
what condition are the rims in ? scratches dings etc...
1 has a small ding in one of the spokes, 2 have very light gutter rash and 1 is unblemished, all need a clean. they're GTS-t rims too, all have practically brand new Toyo rubber.
if you want to check them out let me know
Edited by a31rb25
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
