  • Replies 41
Hey mate, I'm chasing some parts:
1. shock absorbers and bump stops front and rear if they are in really good nick - mine are damaged and leaking
2. I also need a bonnet cable handle - mine is broken
3. Boot struts - mine no longer hold up the boot when you open it.
4. Rocker cover gasket - if you have a new one lying around.
If the parts are in really good condition let me know please.
Hi Patrick,
Sorry I dont have any of the items you need.
Good luck
Chris
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
