  • 4 months later...
  • Replies 53
I'm currently setting up a drysump for my rb30/26 vl commodore.
I got a peterson r4 pump for quite cheap, i just dont know where i can mount it.
I've attached some pictures of it in a hope that you guys can point me in the right direction.
I want to have 3 -12 scavenge stages in the sump and one -10 scavenge from the head.
-16 to and from the tank, and -12 to the block. BUT I THINK the scavenge inlets are on the wrong side,
cos when spun clockwise the pump looks like it pumps the wrong way.
  • 3 months later...
Bringing the thread back to life, does anyone know if you can fit a 6 stage dry sump pump to an RB26? Has it been done before? Pump will be mounted on a bracket where the air-con. was originally fitted.
Why are you wanting 6 stages Mike? 4 is enough for 1 x head and 2 in the sump, plus the pressure stage.
As a general rule you dont want to scavenge the super hot foamy oil from the turbo's either as its not good for the scavenge stage. Instead letting that oil return to the sump via conventional means so it can cool down and release air bubbles.
I'd like to have a try mounting one where the power steering pump is, drive it off the exhaust cam gear, and go with an electric power steering pump.
Edited by GTRNUR
There are some second hands pumps available at good prices that are 6-stage. I was thinking 3 on the RHS of sump, one at the rear and one off the head and obviosuly pressure.
I have read exactly what you have just mentioned about sucking in foamly oil, etc as there is not enough to scavange having so many stages. In between my previous post and what I have read since I do not think it is a good idea.
I do not actually think a 6-stage will fit, I think it will hit the engine mount which ever side you put it on. What you suggested is a good idea too, only thing is you are scavanging from higher up.
Cheers for that Ian, how many stages do you have on your VW?
The pump on the bug is 3 x 1.75" scavenge stages and 1 x 1.25 pressure stage. I use a -16 from the sump and 2 x -12's from each rocker cover.
Having re thought it... even mounting an oil pump where the power steering pump is located would be tricky. Available room is at a premium and clearing the turbo intakes, plumbing etc would be a challenge.
I am in the process of fitting a Peterson 5 stage dry sump kit from "dazmo"
There is still a bit of room behind there. The 6 stage will fit but you will have to block the front turbo oil return hose and tee it to the rear if required.
A small plug for dazmo; his dry sump kit is fairly well designed, packaged and priced. I am impressed with the quality.
this is my 5 stage one. as you can see there is not enough room for it to come back any more because of the engine mount.
this is with a highmout single turbo, stock twins,no chance of fitting.
depending on how the last section is, you may be able to fit it, but i doubt it.
Thanks T04GTR I was waiting for you to post! Do you have any details on your sump mods? I understand if you want to keep it close to your chest, feel free to PM me. Cheers.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
