Hi all,
I have a few LED parker and number plate lights left over.
They are white in colour and are 5 chip SMD LED. T10 Bulb that fits all Skylines.
Will fit parkers, number plates and dash clusters.
Price: $10 pair Delivered
GET EM BEFORE THEY GO!!!!
https://www.sau.com.au/forums/topic/293968-led-parkers-and-number-plate-lights/
  • Replies 55
All PMs sent :D
Ill take two sets please.
Where in sydney are u?
heyy ill take a pair of the parkers.. can u deliver to geelong vic?
il take a set PM details for delivery and payment.
Cheers
Darren
'll take a pair for sure this time! send me your bank details
hey dave,
ill take 2 sets.
pm sent.
Darren, your LEDs were sent off today.
Andrew, yours will be sent off with the HID kit you ordered.
To all i sent PMs to, i need to hear back from you.
If I'm not too late Dave, I'll take 1 pr of led parkers pls
PM me with your bank details thanx, (but I can also pick them up too if it's more convenient 4 U)
Terry
Not too late Terry PM sent.
Terry
PM sent.
Work in R32?
If so, send your bank details :blush:
Cheers Dave, legend mate. :blush:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
