imo... i think they should be charged registration and not be allowed to run red lights, I have seen some real shocking cyclists on the road.
And they should make a lane stricly for cyclists like the ones in the CBD of NSW.. nothing is more irritating then having a cyclist ride 30KM's in front of you in a one way st.... GRRRR
  • Replies 68
Ill carry on from a previous Facebook rant i had a couple days ago..
about 10 or so cyclists, riding down a busy street in seaford/moana, they were riding 5 abreast..and the other 5 were spread apart say..3 metres between eachother..coming up to a large roundabout, they are 10 metres behind the car..we slow down..they dont give way..the first 5 to through, which angered me..because we are about to accelerate..and then the group riding 5 abreast form a single line and fly past us as we are rolling off, and we end up having to give way to their lycra-clad asses. I mean, cmon, seriously, you guys can brake and wait until we have gone through..then they have the nerve to form back up 5 abreast after the roundabout. I have 8 fingers, but only used one when we passed them.
Now i feel like ranter going on about "hoons"
lol register little timmy's trike he gets for xmas
rides up the cul-de-sac and the 5-0 pull him up and impounds his bike for not being registered
should i have to register my sneekers if i walk on a footpath?
give me a break...
it goes each way, respect the cyclist, and respect the faster and far bigger cars.
you play with big boys - you will get hurt.
agreed its a case of minorities being cocksuckers and ruining it for the rest
this will "group" will only start driving a wedge between cyclists and the rest of the motoring community.
and last bit of rant, will these lance armstrongs stick to the 40kmh speedlimits too - i think not
Edited by 910trx
problem is that the cyclists have no respect for the cars or the road rules watsoever.....hence why they are the ones getting hurt and the govt being the kents they are, are going to lower the speed limits (or they are thinking about it)
They wont let the consortium build a race track yet they are going to give the cyclists more lanes....why are they even listening to them they are not paying road users in terms of road tax etc
haha damn right Krishy!
But you watch, Adelaide will create more bike lanes..
Where is our race track?
it was in the paper on thursday... tailem bend or something sounds good but its still a fair drive.. but i like that theres room for: drag, drift, motokanas, dirtracing cars/bikes, burn pad... finally a motorsport area for sa... mallala has too many walls(so close to track) and too much precious grass.. F**k all the grass off!!! and the walls so ppl dont have to have extra risk (car damage) *should have rollcage if your gonna go crazy :cool:*
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
