I wanted to know what the difference was between an RB20DET-R, and a normal road-going RB20DET. INTERNALLY.
the answer i've been given is 'nothing'. all you're saying is that the race and the street version are different - not how.
*gives up*
Think if it as 3 different engines.
Regular Rb20det, sold in regular r31's:
regular stuff
Rb20det-R: sold in a few gts-r's that nissan sold so they could race them:
slightly more than regular stuff, but nothing crazy, someone else can tell you the specifics, because i don't know
Rb20det-r, "race spec": used in the r31's that were raced:
Heaps of insane stuff to make them last longer, put out more power, etc. Again, ask an expert.
Basically, the det-r sold to the public is a step up from a det, but not what they used in the racecars.
(well, i hope i got that right, i'd look silly if i didn't)
Edited by sneakey pete
  • Replies 55
jdm spec and proud :thumbsup:
it's an import dude. bought from the "Japanese Domestic Market. it was JDM they day it was built. you saying it's JDM is just retarded.
thanks eskydude. not that i don't trust you, being a stranger on the internet, but could you confirm that?
i don't know much about nissan motorsport history - interests me quite severely. thanks though.
thank you also pete. shedding some light on topic.
Edited by Dorigecko
so much uncertainty for something so pointless. remember that these cars were raced in japan aswell...
exact quote from the owner of the aforementioned car, if this doesnt help you, nothing can......
Motor basics below.....the rest of the driveline also plays a big part in the performance of the car.....hope this helps.
R31 GTS-r intercooler(sort of....there a GMS story behind it)
8:1 compression for the high comp motor. 7:1 compression for the low comp motor
21PSI on the high comp. 23PSI on the low comp
Nissan Motorsport Block
Custom grind cams(have fun finding blanks)
JE pistons
Nismo Rods
Standard Crank
Garret 3/4 turbo(non BB)
Titanium Exhaust Valves
Stainless Inlet Valves
GMS Sump
Electromotive ECU(Go Motec.....we have to run the original ECU)
PWR Radiator
lol @ RB20DET-R's having a Nismo block with Nismo Rods and American pistsons...
Does this honestly look like a car with a forged motor???
The RB20DET-R made less power than the silver top for gods sake. There is nothing special internally about it other than bolt on goodness to pass homologation requirements.
And then even after that all the parts were changed anyhow as is what happened back in the GrpA days.
If there were some mystically awesome internals the internet would be littered with information, however people that have pulled down original RB20DET-R's have never noted anything out of the ordinary down.
I think the only thing was the butterflies in the plenum like a NICS motor (even though it was ECCS). Which is nothing to get excited about and i can promise you would not have been in the race-spec motors.
JE pistons
Nismo Rods
Standard Crank
GMS Sump
PWR Radiator
That is the RACE SPEC not the normal RB20DET-R you would buy from a wrecker (if you could find one).
Dorigecko has clearly become confused, so im making nice and clear - that above specs ARE NOT THE FACTORY ONES.
the quote im giving is from the ex-skaife car.... not a road going version.
EDIT: which im fully aware of.... it would seem to me that after he saw the video he wanted to know the specs on THAT motor, not the road going version...
Edited by esky_mad
nismoid, tone down the arrogance dude. it's discussion time, not 'i'm right you're wrong shutup' time. chill the f**k out.
so, i've gathered now -
RB20DET-R was in race-spec vehicles, with race-spec external modifications.
800 units were made, some of which used and built as group A race engines here in oz, some used in japan for race, rest kept as standard red-top eccs in GTS-Rs. yeah?
Skaife's was f**king boss.
The hard-revving sound isn't actually hard revving.
actually.... you being ignorant to the fact that the acronym JDM has been colloquially applied to a particular form of styling is retarded
what, a massive cannon and a sticker saying jdm-spec?
get outta my thread because you clearly don't know a goddamn thing about its content.
Edited by Dorigecko
ok....
race spec rb20det-r were in race spec cars
street spec rb20det-r were in street spec cars sold to public
2 different things
lol... try, mostly go fast mods, not much cosmetic, low, fitment.
car makes 320rwkw
pretty sure that's JDM right there
so back on track then...
http://www.youtube.com/watch?v=L2jbS3t77Fw...feature=related
this is ultimately a sound I want to achieve - or rather would like to make nic achieve.
strip your car and you're half way there... srsly
No, I wnat that sound, but I want to keep my JDM interior.
OK no shit, I am interested in getting a hypo 20, Jason is interested about 100x more and has me at gunpoint on the matter, BUT I want to keep my true JDM import semi driveable for street, ie, include interior and shit.
try this one perhaps. this is ex-skaife, and it sounds HORN.
and dude you're not funny. go'way please. don't care how fully sik powerfulz your car is, i want history and you're giving me pretty much nothing.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
