  • Replies 88
hi mate interestd in the front castor rods im willing to pik em up could u pm me plz if there still available
Rods are sold pending payment sorry!
Hey mate, im interested in the Wheels & tyres (do u just have the 2 good ones or is it 4) and the Rear garnish.
thanks.
PM sent
pm sent
PM replied
Hey champ,
Chasing an RB25 gearbox, do you still have it?
Don't have enough posts to PM you
email me at [email protected]
Nick
Sorry mate looks like it's sold pending payment
Im after the headlight stork if u have it. postage to canberra?
Yep still have the stalk. $30 posted to canberra, Pm me if interested
hey phatlavish,
i am interested in the items below...
Drivers door motor - $90
Floormats - $100
pm me where to pick up...
Hey mate, sorry looks like these are sold pending pickup. Will let you know if it falls through
Inetersted in DUMP and FRONT pipe! gotta pm
Also looks like its sold pending payment
Hey after your door trims,
any pics and where abouts are you located???
cheers
Door trims still for sale. i'll grab some pics tomorrow
how much for the serier 2 steering wheel???? what condition is it in????
thanks
Sold pending payment sorry. Pics and peice are in the first post
still got injectors? If so, shoot me a quick PM with some contact details in it. Not enough posts to do so myself. Cheers
Also sold pending payment sorry!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
