hey guys i'm torn between the castrol edge 5w-30 and the motul turbolight 4100 10w-40 for my next service. would like to know pros and cons for both and past experiences. i've read the oil thread and i know the motul gets heaps of good praise but i want to know about castrol edge more from the people that use it especially with the hotter months closing in.
another question i wanted to know is if castrol vmx 80 will be fine for my gearbox and if not what other alternative around that price range would be better? also what can i put into my diff?
i have a daily r33 gtst series II with 105,000kms. thanks
5w-30 will protect better when cold, but depending on the condition on the motor the hot rating might be too thin, you'll only know you have blowby issues is by going ahead and trying it.
hi there guys, i'm facing the same problem choosing the correct oil for my v35 ,engine model vq25dd, hope one of you may be able to advise me of a suitable oil. I live in botswana and it's a similar climate, very hot, i have a choice of shell 25w-60w,15w-40w, castrol magnatic, havoline semi synthetic? which do you think i should use
No other choices than the above 3 (I'd probably chooce Shell or Havoline, hate lowspec Castrol oil)?
If 25w-60 and 15w40 are the only options, then 15w-40 I would choose, 25w is just too thick when cold.
thanks for your input guys. ended up getting the motul.
been recommended vmx m and not the vmx 80. does anyone know the difference? also would like to know if the nulon 75w-90 semi synth smooth shift gear oil would be suitable. nulon suggests their 75w-85 100% synthetic but would liek to know if the semi synth will do fine?
Castrol Transmax M is used for automatics
Castrol Transmax M
A mineral oil based, general purpose, automatic transmission fluid for use in a wide range of automatic transmission applications
its been proven before and if your gbox is in good nick stick to vmx80 and you will be fine
In a good condition RB25 I HIGHLY recommend Fuchs 10w30, Bursons stock it, Have been running it in the Stagea for 40k km, motor is cleaner, smoother, more economical than when i first got it, i have run motul once, wasnt a fan.
Their 10w40 is another option. Motul 300v I understand, but the lower end stuff I dont get the hype. Chuckie has had his oil regularly tested up to 20k km and the fuchs doesn't deteriorate.
Same, smells nice too.. :(
Had a workshop replace the transfer case for me, they put in decent gearbox oil but it doesn't like it, 4th and 5th synchros are a bitch. Going to dump it and go back to the vmx80 that I was running before without an issue.
Ive never had a problem with castrol edge, and ive been using it for about 1.5yrs now, I use 10w60tho. I believe some drift teams are sponsored by it and havent lost an engine.
I haven't had any probs with Castrol Edge 5w-30 for the 3.5yrs I've had my car. it's the only decent 5w-30 readily available off the shelf that i've found and it's the recommended weight in my manual.
my car is NA though.
it would be interesting to know how many of the above mentioned oils are actually certified as meeting there advertised spec. And viscosity as in the thickness is not the spec either. Should be running a SL spec oil or higher which is commonly a semi-synthetic at the very least. Check on the back of the packaging. If its not got the API stamp, then you dont actually know what you are getting and 80% of oils retailed off the shelf havent as it costs big dollars to have a product certified.
Repsol oils are what i used in my shop for 5 years for this reason.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
