Needed to make some room so have to sell my parts.
Located in adelaide.
Reasonable offers considered, but the prices are already cheap so don't be a dick.
Advan Model 5 Wheels - f:18x8 r:18x9. 5-stud, offsets are +35. No gutter rash! Come with shit tires. - $950 Bargain!
HR31 JDM Projector headlights. - $200
Seats, Bride/Recaro style copies. Like justjap sell. Pair in black, pretty much new condition. -$100 pair!!
Garrett T51 turbo. Plain bearing core. T6 flange 1.2 A/R Good for 1000hp. BRAND NEW! - $800!
S13/R32 rear coilovers. HKS Hypermax Pro. 7kg/mm springs. Good condition. -$300
R32 RB20det engine (good condition) All sensors/parts included minus - No turbo, no clutch or gearbox. -$850
VG30 turbo on modified rb20 manifold with external gate/screamer pipe setup. Manifold, turbo, wastegate and dump for only - $350!
R32 RB20det engine loom. $150
Or you can get the rb20det engine with vg30 turbo setup and loom together for -$1100 Bargain!
Everything is in great condition. All the parts are at Japanese Performance Imports if anyone wants to go have a look.
Or call me: 0434 637 357 -Jeff
  • Replies 42
Posted Images
could you please post some photos of the turbo?
*edit*
dont worry, as said on the phone, ill buy :(
Edited by Tocchi
Pics on R31 JDM Projectors please, any damage?
Yes the drivers side one was broken at the rear plastic part where it mounts to the car.
But i had it repaired and used it in my car for a long time with no problems.
The glass and lenses and internals are all good. I will get pics.
I have had a lot of requests for pics for everything and i am trying to sort it out.
Should have some pics up later today.
Cheers
ha ha that is the best avatar picture i have seen in a long time.... took me a while to even realise what it was but it's brilliant
Can't seem to edit my post... but these items are SOLD and no longer available.
T51 Turbo
VG30 turbo/manifold/gate
Picture of the seats. Driver side has cefiro rail. Passenger has R31 rail.
They have sat in the shed for a year and are a bit dusty but it wipes right off.
Pictue of headlights. Also a bit dirty.
Picture of Advan wheels. Forgot to mention they are painted black.
Cheers.
hey jeff
is the gate setup on the manifold? willing to sell that on its own?
Cheers
can you post up a pic of the hipermax's dude. they are 7kg/mm? i need em for a 32gtr, but i think the gtr's spring rates were 8kg/mm. post a pic up anyway dude, one of my rears is leakin bad so i will prolly take em anyway.
cheers,
andrew
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
