Hey all,
After a 4hour drive i developed a slight miss, this miss soon turned into a full blown one now my 180 sounds like a wrx!
I thought initially that it could have been plugs so i changed them.
After this i decided to switch coil pack sequence to see if they were the fault but the issue remained in cylinder 2.
Does anyone have any suggestions of things I can try before sending it to the mechanic?
https://www.sau.com.au/forums/topic/294815-ca18det-dramas/
Plugs, loom connecting to the Coil packs and the earth wire to the coil packs (on the end of the loom close to 4th cyc).
Thanks mate il have a look at that. I woulda thought tho that if the earth became disconnected I would have lost all cylinders?
Im going to see if i can get a compression test done too, unfortunately i dont have the equipment to do it myself.
https://www.sau.com.au/forums/topic/294815-ca18det-dramas/#findComment-4917712
Yeah it would. just means valves either warped so it doesn't really seat, or it's actually fully burnt and has failed, letting compressed air and fuel out before it can be burnt. your plugs will still fire, your injectors will still function, but basically it will sound like shit, go even worse, and yeah... basically just do not drive it because there's a serious problem.
replacing the valve won't solve the cause of the burnt valve though. hot spots in the engine, exhaust gas temperature, shitloads of possibilities.
tell us a little bit about the engine?
edit: is the injector still working in cylinder 2 though?
Edited by Dorigecko
https://www.sau.com.au/forums/topic/294815-ca18det-dramas/#findComment-4924114
Im fairly sure the injector is just knackered, i put a screwdriver on it and then put my ear against it and couldnt hear it ticking while on others i could.
So my question is, if i run injector cleaner thru it will it actually work or am i just wasting money?
https://www.sau.com.au/forums/topic/294815-ca18det-dramas/#findComment-4925623
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
