just purchased a 200b flywheel for my L26 as i was told there all the same..
i have purchased an exedy 260z pressure plate and clutch combo
the problem occurred when i lined up the pressure plate to the flywheel the 260 pressure plate bolt pattern is different to the 200b one
im unsure if ill be able to redrill the flywheel to suit the pressure plate and also have the dowels relocated
as you can see no line up
advice is also welcome
thanks again people!
p.s if you have a 6 cyl L series flywheel in qld id like to buy it
Edited by DAS KAMU
https://www.sau.com.au/forums/topic/294894-l-26-flywheel-fun/
Clearly they're NOT all the same. By the time you have the new bolt holes and dowels machined into this flywheel, you probably could have gone and bought the proper L26 flywheel.
Take the 200B flywheel back, tell the idiot "they're not all the same, bozo", then go somewhere else and get a L26 flywheel.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
