Hey Guys,
Just wondering if anyone knows how to clean the car windows really good, especially the front windshield so the wipers will be smoother. Like i know you can use a clay bar on the car is there something similar you can use for your windows to remove all the tiny dirt and stuff :D
Cheers,
Aleks
Hey Guys,
Cheers,
Aleks
i've heard that you can polish glass with a water based polish, but haven't tested it, or know anyone personally who has. i don't know if this would achieve what you're chasing either. if your wipers are sticking to your windows when they're wiping, try changing from a rubber wiper to a silicone wiper or vice versa would probably your first (and cheapest) option. you could also try putting a small amount of detergent in your wiper reservoir (i generally put in about 4 drops of car washing detergent).
Oh maybe at the same time someone can tell me if there's a way of making the water coming out from the thingy (dont know whats it called) spray instead of shooting a jet fo water.
you'd have to replace the nozzle. maybe try ebay for a quick fix?
I use metho and newspaper for a rag, I was told it's the best for the outside glass becuse it doesnt leave a film that can attract dust and dirt.
I also worked at a glass screen printing factory and thats how we cleaned the real dirty glass for printing.
Isoprophyl Alcohol diluted 2:1 with water. You can clay glass aswell. Follow up with a polish after that as clay bar will leave microscratches. check out www.finalinspection.com the detailing forum is pretty good there and they should be able to answer the question a bit better.
Cheers guys,
I'll give the metho and newspaper a go, because i've heard good things about that from other people, plus i have both of those at home :laugh:, where can i get some silicone wipers and any brand you can recommend, i need the hook connector and i don't want the refills i cant be stuffed just the whole blade lol
I just use Windex and paper towel to clean, if there is any sap or resin on there I give it a go first with Orange Power. I use a turtle wax additive in the reservoir and have perfect window cleaning action :)
there is a window polish available that car detailers and Euro car dealers use .. its 20 bucks a small pot and does 40 car windows you onlt do it once a year.. smooths your class , gets rid of blemishes , and prevents fogging
Bear in mnd if you have cracks or chips in ur windscreen dont use polish as it hardens up inside the cracks causing it to expand gradually..
Cheers guys,
I'll give the metho and newspaper a go, because i've heard good things about that from other people, plus i have both of those at home :P , where can i get some silicone wipers and any brand you can recommend, i need the hook connector and i don't want the refills i cant be stuffed just the whole blade lol
repco / autobarn / superchea has heaps of wiper blade sets.. i got some for the 33 last week - cost me like 15 bucks.. there are more expensive ones like 30-40 bucks but yeah the cheap ones last at least 12 months..takes 2 mins to fit..
I just use Windex and paper towel to clean, if there is any sap or resin on there I give it a go first with Orange Power. I use a turtle wax additive in the reservoir and have perfect window cleaning action :D
Heard thats a good way to clean your face too :P
you do realize metho does have a oil additive and most likely will leave a minute residue.
you could try using a pin to align the ball in the nozzle to get the angle of the jet better so it sprays over a larger area
actually what ytou di is get some window cleaner and some 000 or 0000 steel wool and scrub the f**k out of the glass with the steel wool and window cleaner... thsi removed bad watermarks also
or a razor blade and window cleaner will do the same thing just watch the window surrounds/paint
Isn't that gonna scratch the glass???
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
