Good day!
Does anyone know the exact location of the fuse box for the v35 model ? my skyline has got the air bag light on. I just want to try removing the fuse & clean it a little bit.
cheers
"Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset"
No more Air Bag flashing light or Nav screen warning!!
https://www.sau.com.au/forums/topic/295446-v35/#findComment-4925485
cheers, i will try this
https://www.sau.com.au/forums/topic/295446-v35/#findComment-4925498
I took it & they pluged it in to the computer the out up was " B1166 LH (Open)
Meaning, the fault is LH curtin air bags. & my car doesn't have side air bags.
& the light is back on.
Any interstate professinals have you had this experince before ?
https://www.sau.com.au/forums/topic/295446-v35/#findComment-4938929
I have the sedan.
I'll give you something else to check, cause I'm having the same issue as well. The scanner gave me some wierd message like yours too(can't remember if it was the same though as it was ages ago).
Under each of the front seatbelts there is a connector with a wiring harness. Is it loose? Check both front seatbelts. I snapped the connector one day while trying to adjust it(bloody things don't move). And since then the airbag light comes on. If I hook in the connector with a cable tie, it's good. If I play with it, airbag light comes back. Finally decided to order the part from Japan, will be here in a few weeks.
https://www.sau.com.au/forums/topic/295446-v35/#findComment-4941063
Thankx Skizo, that sounds more like it. did u have it coming each time you were driving ? what was ur error code? B1166 ?
Because the scanner said LH side I gave the LH seat & wiring a good shake & reset using the ON/OFF x 5times. & I have driven about 100k's all around & it still hasn't poped up. so hopefuly it's gone for good.
there is soo much wiring under that seat.
https://www.sau.com.au/forums/topic/295446-v35/#findComment-4941547
Can't remember the code, it's been so long since i hooked up a scanner to it.
Yes the airbag light would come on every time I drove the car. Even after a reset, it would be back the next time I drove the car, until I cable tied it. So in my case I believe that the broken seatbelt connector on the buckle was the issue.
If it comes back let me know as there are some more detailed things you can check as well.
https://www.sau.com.au/forums/topic/295446-v35/#findComment-4942692
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
