Massive thanks to all entrants and to everyone who helped out. It was another great year to sit around talking crap around the very things that bring us all together.
I did NOT expect a trophy at all, so it was a nice surprise! Well done to the FPV Club for taking out best club display.
man i must have been hiding under a rock....misse this one completely after entering the previous two years. congrats damo
  • Replies 224
top effort guys i was thinking a fake rock under one of Matty's tires to show some travel would be cool
Bugger that, you should have seen the mound of dirt 15m behind our display :thumbsup:
Yep, I put in a huge vote for at least the SAU logo to be put on the front of the shirt. Can I give you mine at the sim event to get it done Damo?
If you glance at the T-shirt quickly, it looks like an electric guitar......anyone else see that or is it just the heat, lol
rofl, it does too... to be honest, i had to look at it for a sec to make it all out
