Hey mate is the stock suspension in good condition i need the rear shocks with no leaks for rego and how much for postage to Canberra
Rears are $150 + I would guess about $25 for postage?
Rears appear to be in good condition.
  • Replies 54
how much for gt badges and boot badge?
cheers
Im unsure what badges your talking about.
The badge on the guard isn't a GT badge and there is none on the rear,
Sorry
Edited by JiN_MaN
Hey mate im after the aircon condenser (the thing thats like a radiator that sits in front of the radiator) if its in good condish, offer of $50
Hit me up with a texty if you can im at work most of the time so cant answer,i travel past anzac highway everyday for work so i can pick it up before 3pm or after 11pm weekdays.
0488001069
Cheers,
Jack
Edited by Jack88
0488001069
Cheers,
Jack
Sorry mate I wouldnt take the risk with it. Id say bent/cracked and not worth selling.
