Hello, parts needed asap
Front bar
head lights
bonnet
boot & spoiler
rear lights
radiator
side skirts
Happy to pick up, don't care what color as i will re-spray, thanks.
Dannie
https://www.sau.com.au/forums/topic/295683-r33-gtst-1996/
Front bar
head lights
bonnet
boot & spoiler
rear lights
radiator
side skirts
Dannie
pm sent
https://www.sau.com.au/forums/topic/295683-r33-gtst-1996/#findComment-4933644
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
