  • Replies 135
Woooooooooooo Hooooooooooo 8.9 @159mph the car was great today i need to work on the 60 foot but it feels strong. compak attak here we come!!!!!!!
A big thanx to CV perf, BMS transmisions and R.I.P.S NZ
full trim drag radials and heavy as a mother f**ker
Makes 650kw at all 4 and yes the 3037s are still there
What is your target, is a low 8 within reach :)
Were u running 30psi with c16?
Have any other clips of the car or even the 8sec run?
What is your target, is a low 8 within reach :thumbsup:
I think a 8.70s are possibe. The turbos are running out of puff but look i only ever wanted to run a high 9 in this car so im stoked
I do have videos but im to dumb to know how to up load them. let me see what i can do
Auto was built by BMS performance and it will cop whatever we throw at it.
Edited by superjet760
A big thanx to Shane 1jz747 for organising today. I appreciate it mate
x2...it allowed us to find quite a bit lacking in our set-up. Thanks Shane...Should be sorted for Compak.
Awesome time, awesome car and most importantly awesome fella.
Well done mate.
OMG, if u work on that 60' time it will get closer to a mid 8
i think paul pulled a 1.49 60' (or was it his wife stacey hehe)
1.35 Marko...only a 1.54 today. Stace has done a 1.69 on Federals though...pretty stout!
Edited by Swiper the Fox
Well done mate.
Thanx Paul
We were happy with the out come. I think its got a bit more in it so we will see what happens at compak attak
Wiping drool off face... So nice. Love the sound as it lauches and looks tough as. Hope one day to have a 9sec street gtr!!!! Working on it slowly as we all are ha ha. Is the headlight duct legal? I wasn't sure but seen it on a fair few high horse power gtrs now that are on the street.
Good luck with the car mate. Very impressive.
i think with some suspensions tuning the black gtr has planty left in it, i didnt get to see the 8 sec passes i think i saw 2 9 sec passes and it was a hand full using up a fair bit of the lane. i reckon that auto was a great move, the car is beautiful to look at, i and many other were very impressed with it.
no dramas on organising the day, there will be a few who attended who will not be welcome in the future as they could not adhere to simple track rules of wrist bands and crew sizes.
other then a few trouble makers i think every one had a pretty good day, althought the cressida didnt make it i had a great day helping out our guys and watchin everyone else have a good go.
Shane
Does anyone know what the fastest radial tyred gtr in the world is?
I know croydon wholesale 32 is the fastest street tyred but he uses et streets and they are not radials.
It maybe Mark godzilla motorsports
Can anyone confirm
Thanx
Paul
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
