1997 R33 Series 2 120,000kms
I have owned the car for a little over a year, before that it was owned by a friend for a about a year.
Serviced Every 5000km or less with Motul turbo light 10w 40w
Motul Diff Oil
Redline Gearbox Oil
Modifications,
Apexi Power FC Tuned at 12psi (made 201kw)
Blitz Dual SBC boost controller
Split Fire Coil Packs
Walboro Fuel pump
Blitz turbo timer
R34 Turbo (OP6)
RB20 Wastegate Actuator (10 psi)
Split Dump/front Pipe
3in Hi Flow cat (inside not bashed out)
3.5 inch HKS Hi Power Exhaust
Apexi Power intake filter on custom made Metal intake pipe onto the turbo
(Pod not totally boxed in but covered over see photos below)
Standard RRB20 Blow off valve
Greddy Front Mount Inter cooler and piping
Alloy Radiator
Heavy Duty Excedy Clutch
Braided Clutch Line
Braided Brake Lines (ADR approved)
Master cylinder stopper
Front and Rear Strut Braces
Bilstein Shocks and King Springs
Front Whiteline adjustable Castor Bushes (adjustable on car)
Rear Whiteline Camber Bushes
Work Emotions CR KAI 18 x 8.5 in all round
235/35/18 federal 595 SS on the front (70%)
235/35/18 Sumitomo HTR Z 3 on the rear (70%)
Work Wheel Nuts
M Spec side skirts and rear pods
33 GTR rear seat
Have had the Roof lining, A-Pillar and B/C Pillar trims redone in Black Suede (haven't done the sun visors yet)
Only need front GTR seats and interior done
White LEDs' in the cluster
Have Changed the AC Panel, cigarette lighter surround and ignition barrel surround lights all to blue LEDs'
Pioneer Head Deck (DEH-P6850MP)
Pioneer Front Speakers and tweeter
Pioneer Rear 6in Speakers
And finally the rear "Skyline" Boot garnish lights up red with taillights
There is probably more little bits and pieces i have forgotten but i think that will do, Basically the car has never missed a beat in the last 2 years runs great drives beautifully and handles well. Overall i think its one of the nicest R33's running around. Has been my pride and joy for a little over a year but its time for me to move on, Pictures Below feel free to ask any questions.
Price - $18,500 Will get RWC upon Sale
Plates Not Included
PM for my contact details if you are interested
and have a few more photos too
Cheers Scott
https://www.sau.com.au/forums/topic/296181-1997-r33-series-2/
  • 3 weeks later...
  • 5 weeks later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
