I had my r33GTST box rebuilt last year with completely new bearings throughout and new syncros in second and third. It has probably done 1000 kms since then most of which has been casual sort of driving.
I took my car for a drive yesterday to try and tune my boost controller and now im getting a whine coming when i press the clutch in. Release bearing tends to ring a bell, however i thought this only made a noise when the car was in neutral or the gearbox not engaged. It doesnt make any other noises and the car drives fine.
I run 300kws behind it, however its only ever had the best oils etc.
On a side note, since it was rebuilt it has always crunched into second when the oil was cold. Is this normal considering my new syncros?
Thanks
https://www.sau.com.au/forums/topic/296481-r33-gtst-box/
Thrust bearing it is. It's a misconception that a worn thrust bearing makes a sound in neutral when the pedal is released; this is usually a gearbox related problem as with the pedal released, even in neutral, you have engaged the gearbox. In contrast, thrust bearing issues tend to show face when you push the pedal in because this is when the bearing is actually used.
Should have replaced clutch / thrust bearing when you reconditioned the gearbox...
https://www.sau.com.au/forums/topic/296481-r33-gtst-box/#findComment-4939808
It's not an autochange on the whole word "spigot" but it autochanges the word pig into cop.
Was the thrust race properly greased up when installed? It could be the spigot bush...
https://www.sau.com.au/forums/topic/296481-r33-gtst-box/#findComment-4942627
Hi Birds, thanks for your posts.
It was done by the engine reconditioner so in all honesty im not 100% but it didnt look too bad. How long do you think it is likely to take me and a friend (hes a mechanic but hasnt done one of these before) to remove gearbox (we have a hoist) remove release bearing and "spigot" and press in a new one?
You seem pretty onto it with these? Where did you get the knowledge from?
So basically its not a gearbox problem due to the gearbox not being engaged when the clutch is pushed in, and its likely to be one of these bits?
https://www.sau.com.au/forums/topic/296481-r33-gtst-box/#findComment-4943506
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
