Hi folks, another lurker on the forum.
In the future I may be interested in doing some minor cosmetic upgrades such as side mirrors and possibly a body-kit for my A31 however it's very difficult sourcing them where I'm from. One will be hard pressed to find an Autech kit in my country and that's exactly what I would like. I won't even have access to an original so that I may mold a copy.
As far as I'm aware most cosmetic parts for the A31 are specific and/or are custom pieces BUT I would like to be proven wrong.
If there are any known substitutes can someone please enlighten me.
Edited by Conrad 2NR
https://www.sau.com.au/forums/topic/296561-cosmetic-similarities/
Mirrors may be usable from other Nissans, but as far as I know there's nothing.
Other cosmetics you can do...ah...paint the strips on the door the same chrome as the door handles / lining around the windows, Ive seen that and it looks pretty mint.
If you do some searching you'll see what kits are available for the Cefiro's, there's a few in Aus, Japan, NZ, there's even one in the USA that comes up on eBay sometimes.
Check out vented guards by Dmax, they also do a body kit and a vented bonnet as well.
You can convert the front end (guards, headlights, grille, bumper) to C33 Laurel.
Import Monster pulls some cool shit out of YahooAuctions-Japan, like rear roof spoilers, clear indicators, etc.
Those stuff are well and good but to get them imported into the Caribbean will prove to be a pain.
Not too fond of a C33 front end on my A31.
Thanks for the points so far though, keep 'em coming.
you can use the C33 laurel mirrors from memory. The plugs and mounts are the same anyways.
as for bodykits, you can use the underskirt of a early pre facelift 180SX, flip it upside down and use it on your standard bumper as a lower lip.
The fitment of the bodykit is unique to the ceffy, but you might be able to shoehorn C33 laurel sideskirts on there.
just curious, whats the difficulty with getting parts sent to you from overseas?
long wait? expensive freight costs? etc?
I'm from Trinidad, our situation is special in that there are areas throughout our country that are quite popular for sourcing foreign used parts (wreckers that import containers directly from Japan full of used parts). Most of our vehicles are JDM, Nissan & Toyota are the most popular brands with Subaru taking on a segment of the market relatively recently as well.
Mechanical parts are relatively abundant, especially if you're a regular/popular customer you'll be able to catch a couple of deals. The problem arises for cosmetic parts, they're usually not in the best condition and sometimes they're outright not available UNLESS, again, if you know the correct people you may be able to source what you want directly out of Japan.
To your original question, parts are relatively easy to source out of the US, so polyurethane bushings and other suspension pieces for the USDM 240SX can be bought new. The issue is with car products the duties are between 30%-40% of the invoice value, so often people under-value their parts to pay less duties. Via air-freight from the states, it can take as little as two days from the click of your mouse to picking up. Via sea-freight it can take up to 6 weeks from the US.
From Australia, I'm not quite sure the length of time taken (I'll guess 3 months, similar to what I've heard a container takes from JDM land) but I can only imagine freight will be a killer though. A few items such as chassis braces and Whiteline products have been done before. Due to the already established connection with Japan, parts will be quicker sourced from there.
If anyone is willing to establish connections with local dealers I would say give it a go as there is a relatively large car scene going on despite not having a track to run on at the moment.
The most popular automotive based website in our country, Trinituner.
I personally will love to have a RB30 block and ViPec ECU sourced out of Australia however my budget says otherwise at the moment.
ahh, understood! cheers.
For sure, budget is everything at the end of the day. You could probably land anything you want there in Trinidad if you have wealth to cough up
Nice Ceffy too by the way!
Thanks for the compliment mate.
  • 3 weeks later...
genuine ceffy kits are pretty expensive from Japan - i reckon you should try to find a smashed stock front bar around your area and then get a cheap kit from another car you like the look of. Get some fibreglass, bog and a decent cuttingl tool (Dremel's are awesome) and make your own bar. Once you've got it looking the way you want sand it all back & paint it.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
