whats the story with the 34 conversion?
theres one in adelaide thats got no reo bar, and fiber glass front 1/4 panels... cant insure em aparently :S...?
sell the 260.... keep the leather seats....has sunroofs and xenavi... already gota tow bar for a jet ski... very nice :P
https://www.sau.com.au/forums/topic/296677-r34d-stagea/#findComment-4942124
If done correctly, there is no reason not have a reo bar. It should have. There again, it was built by Viva
If you use the R34 GTR genuine reo bar ($1000-1200 new approx) it pretty much bolts directly onto the stagea chassis rails and has plenty of room for a FMIC.
My car is fully insured and listed with the front end conversion. The only f/glass in the front end is the front guards. Techinally they are not adr approved, but it is possible.
MIKE, unless the R34 support is used, you have to trim the stagea support to fit the headlights
Hey Mitch, don't sell it too soon, hopefully catch up with you before xmas for a few photo's
I have decided my car is no good now for a tow vehicle as well, can not see me leaving it at the boat ramp in the dark hours. Just ordered a new Kluger for the job. Have a 3 week road trip in Jan with jayco camper.
https://www.sau.com.au/forums/topic/296677-r34d-stagea/#findComment-4942462
X2- insurance company are aware of all the mods done to the front end. All genuine R34 GTR parts used- however as with Darrin the front guards are not metal, but are excellent quality! Car has no dramas getting roadworthy
My understanding is the rad support has been modified slightly for headlights. See the previous owners build thread here- you will see this was a top job using quality parts:
http://www.skylinesaustralia.com/forums/R3...io-t195041.html
Edited by EvoMitchy
https://www.sau.com.au/forums/topic/296677-r34d-stagea/#findComment-4943819
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
