Could be one of those aftermarket kits for an R35 style front conversion. I've seen a few going around on the web.
Here's one example - but its on an M35 Stagea - http://www.webwombat.com.au/motoring/news_...ation-wagon.htm - Personally I think it looks quite smart.
I "imagine" to fit it to a V35/G35 would not be too difficult.
Yeah, so that ones a half cut i think. Pretty common with 180s and silvias
"Not quite" a half cut. Reason being is a "half cut" by definition includes the structural parts and generally the engine etc. Literally a "half cut" from a donor car.
In this case - the panels are either purchased and modified to suit or custom copies are made up, Majority of the time there are no mods the the actual structure of the vehicle. I'd say more of a "re-skin" more than anything.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
