Engine Conversion And Gearbox Change?
Ok just need a quick help on something. Google has yielded no help.
I'm thinking about doing a Auto > Manual conversion on a R33, Either GTS or GTS-T. Since you guys know alot more than I do would you be able to point me to some places in melb that do the job and arn't going to take my right arm along with the price tag and how much i'd be looking at?
Possible links to websites means i love you long time :)
Thanks in advanced guys :P
Honestly......with the amount of manual R33's around... doing an conversion (NA-turbo or auto-manual) is just not worth it. You'd be looking at anywhere near $2,500-5,000 for manual conversion.
I thought of doing a manual conversion for a R34 auto, but didn't end up doing it, coz it's not worth it. So i looked harder and found my yellow R34 manual lol.
Good points Charles...I too don't see the point in converting something that is so widely available in manual form.
+1 on that. There aren't a whole lot of automatic Skylines around, they're predominantly manual.
I'm getting a manual conversion on my 300ZX (only because I couldn't find a decent manual one anywhere) and it's setting me back around $4000. A lot of money in the scheme of things.
Sell current car. Buy a manual one. Simple as that. Less wasted money. Less headaches.
RB25 box + tailshaft, xmember etc is $1500
If the rest of the conversion is going to cost you another $3500 then you are being stung silly.
Include a clutch, slave/master and labour, you'd be hard pressed to spend much more than $3500 overall for a manual conversion.
Then you add to the fact you could likely sell the auto for $500, makes it a 3k adventure.
Is that directed at me? I said $4000 for a 300ZX conversion :D
For parts alone it's costing me $2500ish. That includes gearbox, pedals, booster, clutch, flywheel, hydraulic piping, tailshaft, clutch master, clutch slave, etc.
$1000 - $1500 is what it will probably cost me to pay a ZX specialist to do the labor. They're not cheap...
Assuming the second hand / lucky dip gearbox drives 100%...
No, the figure of upto $5,000 posted earlier
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
