There are pickpockets too...
My favourite weapon atm is the big ass maul as you smash the f**kola outta people.
You get poison for your daggers that makes guards go beserk on their own guys ^_^
dammit i gotta get my shit together and pay mine off, 110 to go lol
an improvement on the first game for sure, but still a bit repetitive
good time waster until bioschock 2 & mass effect 2 for me
I love it when those couriers run right into my path, just knock them over & bam easy 1500
  • 3 weeks later...
got my copy of white edition, black was all sold out :banana: would have liked to get the black figurine and the 3 bonus quests instead of just the one that comes with white edit.
so far the game is much the same as the first in its repetitiveness (i dont mind too much), but its nice being able to buy new weapons and armour, and change the colour of your costume too
SO you guys have had a fair amount of time on this...
Would you recommend it to someone who DIDN'T like the first one?
The idea behind the first one was good... in theory, but in practice it was boring and repetitive. Will I feel the same with the new one, or is it so drastically improved i'll probably get in to it anyway?
more of the same than anything else, just that mission sequences are not as strictly linear as the first game
the world itself is beautiful & the game is pretty much a f**k you to religion so a definite plus for me
hate that annoying british smartass prick who talks too much, luckily there's only a few scenes with him in it
& those guys with instruments that replaced the beggars from the first game that run up & block your path are annoying, I enjoy beating them up, throwing them down wells etc
lolz, damn musicians, just steal from them and theyll run off.
MaTBoY - if you didnt like the first at all, then you probably wont like this, it is still repetitive but there is a little more fun to be had being able to steal/chase down pickpockets and messengers/ use an array of different weapons and many other random off the storyline stuff.
You gotta make sure you do it to a guy standing behind another otherwise he misses them with his weapon....
Most fun thing to do is get 1 guy on 1 end and another guy on the other side of their pack and watch the guards get smacked back and forth between them until they both die lol classic
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
