Have a few bits and pieces off a stagea and R33 GTR
Parts list and prices
Whiteline Rear Upper Control Control Arm Bushes BRAND NEW W0579, $70ono
Genuine Momo Steering wheel. Typ D35 KBA 70116 is the model. In excellent condition, only very minor wear marks. $170ono
R33 GTS4 stock shocks w/ aftermarket springs, Shocks are in ok condition, no signs of leaks. As for springs there in good condition just not 100% which brands they are, being red, either pedders, nismo or apexi springs?. They might be pedders but I'm not 100%. Came off R33 GTS4, assuming they may fit (correct me if wrong). $200ono
R33 Series 2 VCT N/A Motor RB25DE 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Pulled out of running vehicle. DROPPED PRICE TO $550ono take it now or it goes to my friend soon. Includes 4WD Sump and Front Diff and shaft, wiring loom and ecu iridium plugs, exhaust manifold and intake pipe. Drops straight into a stagea.
NOTE: Took off some parts as I needed them. These include, water pump, tensioner and idle bearings, harmonic balancer, A/C and pwr/steer pump. So just pretty much the 100,000km service.
R33 GTS4 Series 2 4WD Gearbox . 114,000kms in good working condition, I beleive it bolts up to stageas as well. $400ono
R33 GTR Front 5 Stud Hub Assembly $150ono
Stagea Front swaybar $20
Stagea Rear swaybar $20
Stainless steel Cannon Muffler Angle Cut Tip - 2.5'' Inlet, 5.5'' Barrel, 4.5'' Angle cut Tip
Very good condition no dents, came off R33 $40ono
RB20/RB25 Crossover pipe in good condition - $20
Gates Timing belt used 10,000kms only $45ono
RB25 Flywheel, Factory in good condition fits RB20 as well. $45
PICS UPON REQUEST
0412 297 325
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
