Up for sale is my 93 180sx (140,000kms), factory black with a 1996 sr20det blacktop in it (90,000)
I have receipts for all the following and the above engine with notated kms.
Engine -
Garrett 2871r
CRD Front Mount
Drift catch can
Apexi power air intake
Bleed Valve (10psi never higher)
3 inch dump
2.5 inch cat back
Xforce muffler
3 month old exedy sports tuff hd clutch
Everything else -
Bride Brix 1.5
Koya Drifteks 17x9.5 +18
Professionally flared guards
Vertex skirts
Pioneer cd/mp3 player with ipod jack
Gktech steering wheel and boss
Height, camber, damper adjustable coilovers
lots of fun and very reliable car, have spent too much cash on her, but need something bigger.
Never tracked, drifted or boosted, serviced every 5000kms with genuine nissan filters and motul lubricants, has been well cared for.
Asking 10,500 with the Bride and Drifteks,
10,000 without the bride
9,500 without the drifteks (Black 17inch racing hart concept fives will be supplied)
Located in Sutherland Shire
Call or text 040399391
Nick
https://www.sau.com.au/forums/topic/297439-180sx/
not too keen on all the dramas swapping cars interstate, very nice car though. I am interested in swaps though, keen on skylines and celsiors and even a 4x4. Forgot to mention the car has a Bosch 040 intank fuel pump. Add a power fc and a tune and the car would be pretty powerful.
https://www.sau.com.au/forums/topic/297439-180sx/#findComment-4955869
Understandable mate.. Pretty keen on yours.. However if you do change your mind and keen to work something out let me know..
https://www.sau.com.au/forums/topic/297439-180sx/#findComment-4956023
No worries will do. Having some trouble replying to PM's, sorry to those i have not gotten back to. Also to anyone who wants to view the car this weekend, it is currently stock, had to take out the goodies to pass an EPA test, but will be putting everything back on over the weekend.
https://www.sau.com.au/forums/topic/297439-180sx/#findComment-4959201
New pics,
Forester - very clean mate but not really what im looking for.
Stagea - Will have a think and let you know.
Just installed whiteline adjustable strut braces front and rear. Also forgot to mention it has quite dark tint.
Edited by nsgreen
https://www.sau.com.au/forums/topic/297439-180sx/#findComment-4961123
  • 3 weeks later...
apologies for that and to anyone who has tried to contact me via my mobile
correct number is 0403993941.
To people who keep ringing asking me if the wheels are for sale seperate - if the car sells without them yes. I will post when the car is sold and whether or not the wheels are available.
https://www.sau.com.au/forums/topic/297439-180sx/#findComment-5000114
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
