i would put money on, street legal car & i mean any wouldn't out drag huybusa street legal only because even a street legal car with mega hp just will not get enough traction off line to do it (with sticky slicks then possable but then your doing mods which is not the point).
  • Replies 46
English much?
what?
haha about time ppls goton about bikes, we've ran lots of bikes in the past. my line comfortabably beats a stock r1 standing start , but last i raced a hayabusa, they have got serious stick from 150 onward and no, a 10 sec car would not beat a hayabusa rolling, the best way to run bikes is from standing start and use scare tactics(cheating). Also an r1 or any 1000cc onward jap bike with some minor mods are out of reach to street reg cars, but then it would take a VERY good rider and balls of steel to sit a couple of cars infront of a line at warp speed.
Hungry,
The movie I sent to GTRREX shows a 10sec Supra (my estimate - it may be faster) beating a Hayabusa from a 70mph rolling start. That movie aside, I agree with you though. Generally, with a rolling start you've got basically zero chance of beating anything above the smallest capacity bikes.
Check out this beast...
2002 GSX1397R Suzuki Turbo Hayabusa
Turbo Photos
The Reincarnation of
SK II
(Velocity Race System)
This motorcycle was built to be as radical as possible and as practical as possible. In its present form it is able to maintain everyday reliable street use, just awaiting thee occasional road kill ;-)
It is built to run over 500+hp (372kw) and 379nm of torque & up to 30 lbs of boost
It is equipped with a Velocity Racing Turbo System, The "Hayabusa Race Turbo System"
Engine is fitting with the following
JE 1397 Turbo pistons
Carrillo Rods
Yosh (Kaotic Cam Timing) cams
HD valve springs
R&D trans w/ HD output shaft
Billet clutch basket/hub/2 stage lock up
Total Kaos Clutch cover
KWS head with larger valves & ported head
HD starter gear
Base spacer
Total Parts list
Velocity Racing / Race Turbo System
MARCHESINI FORGED MAGNESIUM WHEELS
Michelin Tires
VORTEX REAR SPROCKETS - 37 39 41 (BOTH SETS OF WHEELS)
GALFER FRONT WAVE ROTORS
GALER REAR WAVE ROTOR
TKP 4' SWINGARM
YOYDYNE TITANIUM ROTOR BOLTS
OHLINS FORKS - 02 SPEC WSB W/O3 INTERNAL UPGRADE
OHLINS SHOCK
OHLINS DAMPENER
AP RACING 4 PISTON MONOBLOC RADIAL MOUNT CALIPERS
AP RACING 2 PISTON REAR RACE CALIPER
AP BRAKE PADS
YOYDYNE REAR CALIPER BRACKET
GOODRIDGE FRONT KEVLAR BRAKE LINES
YOYODYNE REAR 2' STEEL BRAIDED LINE
MIKUNI BRIDGE KIT WITH CLIP ONS
PVM FRONT BRAKE PRESSURE SWITCH
PVM RADIAL MOUNT AP RACING ADAPTERS
PVM 14 WAY ADJUSTABLE BRAKE MASTER CYLINDER
PVM 14 WAY ADJUSTABLE CLUTCH MASTER CYLINDER
GILLES REAR SETS
VELOCITY LOWERING LINKS
YOSHIMURA EXHAUST BRACKET
DID 530 ZVX X-RING CHROME CHAIN
FRONT SPROCKET FOR H/D OUTPUT SHAFT
KICKSTAND RACING CLUTCH SUPPORT SPROCKET COVER
YOYODYNE FUEL CAP
STAINLESS STEEL TB BLADES
TKP CLUTCH CASE COVER
FULL R&D TRANNY
MTC BILLET CLUTCH HUB
MTC BILLET CLUTCH BASKET 0
MTC STAGE LOCK UP CLUTCH
3mm JE TURBO PISTONS
FALICON H-BEAM RODS
YOSHIMURA STAGE 1 CAMS W/SPROCKETS
KWS HEAD - PORTED/FULL RADIUS VALVE CUT - 1' EX VAL - BRONZE VALVE Gd
APE 1mm STAINLESS STEEL EXHAUST VALVES
APE HD STARTER GEAR
VELOCITY TURBO KIT (RACE SYSTEM)
MUZZY FAN
RIZOMA BILLET BRAKE RESEVOIRS
YOYODYNE WRX CLEAR BRAKE TUNING
BILLET KICKSTAND
BILLET REAR SWINGARM SPOOLS
CLEAR ALTERNATIVE FRONT & REAR LENSES
CUSTOM PAINT
CUSTOM DECALS
HD VALVE SPRINGS
MTS CYCLINDER BORE & RENIKASIL
APE MAIN & CYLINDER STUDS/NUTS
APE MANUAL CAM CHAIN TENSIONER
JEFF WALLACE DEALER MODE SWITCH
220 FACE GAUGES
BOOST CONTROLLER
GALINDO SUPERBIKE GRIPS
SECOND LOOK SEAT COVERS
LABOR
Motorcycle New
PC III R
Go to TotalKaosPerformance for some more crazy turbo bikes
well i own a busa bought new feb o3 $18000 registered on the road has 4into 1 micron system and airbox mod s&r performance dynoed it was running 168rwhpwith only 2000k's on the clock going a lot better now & i havnt cum accross any car quicker than it yet that i cant pass ib first gear they do get me of the mark but thats mainly cause i dont wanna flip it as to date it is still the fastest mass production bike on the market ride one and u'll c y
1000 HP GT-R33 vs Hayabusa 1300cc
The Clip is at this website
Youll have to join them to watch the video, its free though.
Then go to Videos, browse videos and its in Street racing
They have alot more vids, Mines R34, r33 GTR vs 911 Turbo, Skyline vs WRX,a few more on other cars too
RACING FLIX
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
