  • Replies 304
Posted Images
na i just took out the seats as its real easy to do.. two bolts and it pulls out!
5 Screws and centre console is out too... :laugh:
With the PERFECT location to mount extinguisher with ZERO mods.
I still can't work out what this has to do with patience doof???? The bear is a kamekaze who will take out 3 canadians aswell as itself????
guys - can you please update the list? I need to know whether to get the car ready or not and i need to equip my mate with a licence if we're on the list!
+1 guys, i need to know if i''m just fixing a power steering line, or whether i'm doing all the fluids as well in preparation.
Those who have to prep cars care...
I also care, because I want to see the photo taken 4 seconds later...
I recon every living mammal in that pic died 4 seconds later
Entries are CLOSED
We will not be accepting any more entries from this date forward.
Information about wether or not previously entered people have made the 'cut' or not is to be determined at a later date, hopefully VERY SOON!
Sorry for the inconvienance.
one thing, can we make sure on the day to tell people to circle all the way around the parking lot & line up along the edges?
seems simple enough but we had a bit of issues last time where the entry/exit area was banked up because people lined up between the first & second lane of parking spots, & I think we have more attendees then last time for this one too
Hi guys,
DUNCAN/N1GTR ive just paid my entry fee for texi as per instructions on page 1 :-) i also hear you guys have my details from gergor. will be printing all paper work and filling in over the next few days.
Hopefully i now have a spot for texi, looking forward to it now as this will be my first time doing something like this :-)
Any word on the blue triangle issue, because i dont have one???
Ben
Dont need a blue triangle
The 8 Camaro entrants are friends of mine. Can't run these events if we don't have the numbers so I filled 25% of the entrants grid ;)
You guys think gts-t's handle like boats, we are about to see some 1960's old school boats try and turn corners :)
Cheers again Ben
I sent my form in and paid on 23/12/09 but I'm not on the list. Am I likely to get a spot?
Yes
you better be f**ken sorry.
f**k you, dont be so lazy sending an entry form in
List updated.
No more entries.
If you have sent in a form already, and arent on the list, please PM me. Only PM me if you've already sent in a form
If you missed out on this one, dont wait until 2 weeks before the event next time :)
it's not lazy (although i am), it's called making sure you can attend an event before entering
p.s - don't be so lazy updating the entry list.
Been busy - look at the start date of this thread anyway
Settle pettle
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
