I have no idea what these are and where to get them :D . Can anyone enlighten me as i've been informed that my slave/master is rooted.
Sorry for the noob question.
depending on what model you car is
master cylinder - located infront of driver side (dont mistake for brake master cylinder - refer to owners manual)
http://www.kudosmotorsports.com/catalog/ni...issan-p-62.html
slave cylinder - located under car along side the transmission
http://www.kudosmotorsports.com/catalog/ni...33r34-p-59.html
shop around for prices
Hmm well I have a GT-R gearbox so i'm guessing I need this one => http://www.kudosmotorsports.com/catalog/ni...3334-p-384.html
Is it worth changing the slave as well to be sure? The symptoms are that as it gets hotter the clutch pedal moves higher up the pedal to the point of it slipping on 35+ days.
33gtst masters do fit on 32gtst's (need to modify the rod slightly), the 33 item is shorter and people use them when putting forward facing plenums on.
32gtr master is different as it is vacuum assist (and have special cutouts in the firewall etc). If you are putting a GTR box in a GTSt platform then you have to use the GTSt master cylinder.
I also have a funny feeling that GTS4 is the same as GTSt, not GTR.
Edited by bubba
Yes I believe you are correct as well.. and I don't want to trial by fire :P. I'm sure the GT-R unit uses the booster, but i'm also sure it is often removed because it doesn't add a lot to the equation. In this case to people switch to gts-t masters?
GTs4 here, GTsT master cylinder.. piece of piss to change. Bought mine from kudos as well.
master --> http://www.kudosmotorsports.com/catalog/ni...33r32-p-60.html
master and slave package --> http://www.kudosmotorsports.com/catalog/ni...-gtst-p-61.html
pic there is the same as what I have bolted on my car, after I had gotten a few frights with the clutch pedal sitting on the floor.
Edited by heller44
Ya i've had advice from professionals that I should use a gts-4 master and gt-r slave :S. But most advice points to gts-4 master and slave. The question I guess is what is the difference in slaves? do they all bolt up the same (even push on pull?).
Get under the car and look. In the package there is a pic of the gtst one, looks like one mounting hole each side of the body. On the gtr / gts4 one there are two holes on one side.
If your car is push, it will have the clutch arm to the rear of the slave cylinder, pull other way around towards the front.
If things are still not clear, get a picture of each and throw it up here.
Hehe car is at a workshop atm.. but thanks for that advice I will definitely check ASAP. I definitely have an early R32 GT-R gearbox (push type) as that's the clutch I just put in it :P. I also definitely have a GTS-4 master cylinder.
gts 4 slave cylinders are very slightly different. GTR slave's have an indent where the nut locks into to stop twisting. I have a spare GTR slave and master cylinder sitting at home. Might want to change the seal on the slave (not manditory) and the master is in excellent condition (used).
The question is.. is there any functional difference between the two? as in running a GTS-4 master but a GT-R slave would leave the clutch engagement at the wrong spot? Or is it simply a difference in the mounts? I'm certain the GT-R and GTS-4 masters have different ratios.
.. Mine works.. on an ORC twin and feels good. Just adjust it for the right pickup point. Massively light compared to the original single plate that was in there, ex wouldn't drive it cos took too much force to hold the clutch pedal in.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
