My friend has a RED TOP RB20Det NICS engine, what boost can the engine run? say the turbo get any psi, on a STOCK. What mods could get this figure higher.
I'm no expert, but personally..I wouldn't take it over 10 psi with the stock intercooler and such. It might even handle 12-14 pounds, but why risk it? I tend to be a bit paranoid about such things, so if you're set on raising the boost, might want a second...or third opinion. :) Good luck.
Hi guys, our experience has been that much more than 1.2 bar on the standard turbo super heats the air and the standard cooler can't cool it. So it looses power and detonates like crazy, till it finally kills a ring land or two.
If I remember correctly, 1 bar = ~14.1 pounds of boost, or so?
I've had my R32 for over 2 years now clocking up 60,000km's.
I had the exhaust fitted wich upped the boost to 10.9psi.
I had a bleeder fitted and upped boost to 12.5psi with a fuel pressure mod which worked well with the stock fuel pump as the a/f was perfect through out the entire rev range. It made 152rwkw.
I then richened it up a little my self and pumped boost up to 14psi where it stayed for 3 months.
I had the FMIC fitted and wound the boost up to 15psi, BUT it would drop in the higher rpms to around 12.5-13psi. Peak power was 155rwkw.
I fitted a EBC that held boost through out the rev range. Boost was set to 15psi and made 164rwkw, timing was dropped back a little to near std as summer time came.
I have since removed the EBC (sold) and fitted a bleeder which in the mid range up to around 5500rpm runs 1.2bar (17psi).
Still hanging in there..... :D
I should speak to soon as it may go pop. ;)
1 bar = 14.7psi
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
